Ideas
My thoughts are now that its the spider injector setup I think I'm going to go to the junk yard to see if I can grab one and see if I get lucky before I spend 300+ for a new one.
Thanks
Thanks
That's one part I would NOT even consider buying used from a junkyard. I know it's pricey for a new one, but since they're so prone to fail, you're only going to get one that most likely will go bad quickly.
I don't believe it's a fuel injector issue. If the injector is leaking, you'd have a drop in pressure when you tested and you don't. If it's clogged, the truck won't run properly. Doesn't seem like that's the issue.
so last night driving home from work CEL comes on again it was off for 450 miles the same dam code came back p0440 I already changed the purge valve and vent valve what the this truck is driving me nuts....
jmatt07
Dec 18, 2009 09:48 AM
