Identifying a sensor
Old Aug 22, 2007 | 05:10 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default Identifying a sensor
My brother found a "sensor" dangling loose underneath his 95 4.3 4x4 Blazerafter some vigorous off - roading. I haven't seen it but he described it as looking like a spark plug a with spring loaded BB at the threaded end. No changes in the way it runs, no check engine light, and no fluid leaks. The wires seem to originate somewhereat the back of theengine compartment and are long enough to have allowed the threaded end to drag on the pavement on the way home.
Does this part sound familiar to anyone?
Old Aug 22, 2007 | 05:37 PM
mdemers2006's Avatar
mdemers2006 is an unknown quantity at this point
Default RE: Identifying a sensor
Can you get a PIC? I could check on my 95 ...
Old Aug 22, 2007 | 05:46 PM
fnirish's Avatar
I doubt he can get a picture to me - no internet. It almost sounds like some kind of pressure switch considering the spring loaded ball in the end. Mine isn't a 4x4 so I'm not familiar with the switches on the T-case for them.
Old Aug 22, 2007 | 06:10 PM
Hum...I know I have something similar on mine,its located on top of my driver side fender.Its got nothing hook up to,I always wondered what it was...I'll send you a picture,maybe its the same as your friend except mine is still hooked-up...Gimme a couple of minutes.
Old Aug 22, 2007 | 06:20 PM
fnirish's Avatar
Thanks!
Old Aug 22, 2007 | 06:40 PM
I have a Pic but I cannot seem to find anywhere to attach it! call me nuts men!Add image = URL !?!Gimem your email & I will send it to you if you want.Or via messenger if you prefer...
*Combining Consecutive Posts*
oppsss........I had to press REPLY for the "click here to upload" to appear..hihihi!!!I must be nuts[8D]
*EDIT by swartlkk* - Combining Consecutive posts - Please use the EDIT feature to add additional information to your post if another member has yet to reply. Please PM me if you have any questions. Thanks!
Old Aug 22, 2007 | 06:48 PM
fnirish's Avatar
Thanks for the picture! Is that a vacuum hose that it's connected to or is that insulation for wiring? It's possible that it could have fallen down from there.
Old Aug 22, 2007 | 06:58 PM
You know what,I have no clue & I wish I could know! I'ved looked in my GM shop manual and I cannot find info.It sure looks like a hose tough(its long),if its for wirring then i'll be dammed!
I'll look at it tomorrow when its not dark,i'll follow the line.I'll also look in front of the firewall for more possible sensor wires, spring loaded BB...
I'm sure the expert on the site would know...
Old Aug 22, 2007 | 07:10 PM
fnirish's Avatar
You're a good soldier - thanks for the help!
Old Aug 22, 2007 | 09:17 PM
What is pictured above is the vent for the front differential.
Really need to see a picture of what it is that your brother has a question about to be sure that we properly identify it...
