-   -   idk what it is but i need help fast......!! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/idk-what-but-i-need-help-fast-58693/)
steven Dougherty May 4, 2011 09:29 PM
i have a grinding sound coing from the driver side front tire. idk what it is i thought it was my breakes but i changed them and the grinding was still there. someone told me it was my ball bearings going out but im not sure... will some one help me fast i need to fix it so i can start lifting it and putting tiers and wheels on.:icon_hyper:
Outsydr May 4, 2011 09:44 PM
Help us to help you...year, 2wd, 4wd etc etc the more info you give the easier it is to help
steven Dougherty May 4, 2011 09:46 PM
its a 1997 s10 blazer 4x4.
Outsydr May 4, 2011 09:54 PM
I'd start with checking out the hub assembly search for it there are tons of threads on diagnosing this to be certain before spending the money (they aren't cheap) HERE is one to get you started, let us know what you find and we will do our best to assist further.
steven Dougherty May 4, 2011 11:12 PM
okay thanks man. i'll let you know when i start to fix it.
Sturg May 5, 2011 04:47 AM
Sounds like wheel hub bearing to me.
steven Dougherty May 5, 2011 09:19 AM
are they hard to replace or would it be better to have a garage do it?
Surgin May 5, 2011 09:23 AM
You can do it at home, use good parts or you will do it more than one time. Do both sides while you have the tools out.
Justin
Sturg May 5, 2011 10:40 PM
Yupp just do it at home, I (because I'm broke) just did one side and used the hub they sell at autozone and it worked out fine for me. I ended up doing the other side like 6 months later though lol. If you can afford it do both.
Rottidog May 5, 2011 11:11 PM
Drive at highway speed for 20 mins or so then pull over & feel the front rims near the center. If 1 side is warmer/hotter than the other then there's a good chance it is the hub bearing assy. that needs replacement.
