idk what it is but i need help fast......!!
Old May 4, 2011 | 09:29 PM
steven Dougherty's Avatar
steven Dougherty is on a distinguished road
Exclamation idk what it is but i need help fast......!!
i have a grinding sound coing from the driver side front tire. idk what it is i thought it was my breakes but i changed them and the grinding was still there. someone told me it was my ball bearings going out but im not sure... will some one help me fast i need to fix it so i can start lifting it and putting tiers and wheels on.
Old May 4, 2011 | 09:44 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Help us to help you...year, 2wd, 4wd etc etc the more info you give the easier it is to help
Old May 4, 2011 | 09:46 PM
its a 1997 s10 blazer 4x4.
Old May 4, 2011 | 09:54 PM
Outsydr's Avatar
I'd start with checking out the hub assembly search for it there are tons of threads on diagnosing this to be certain before spending the money (they aren't cheap) HERE is one to get you started, let us know what you find and we will do our best to assist further.
Old May 4, 2011 | 11:12 PM
okay thanks man. i'll let you know when i start to fix it.
Old May 5, 2011 | 04:47 AM
Sturg's Avatar
Sturg is on a distinguished road
Sounds like wheel hub bearing to me.
Old May 5, 2011 | 09:19 AM
are they hard to replace or would it be better to have a garage do it?
Old May 5, 2011 | 09:23 AM
Surgin's Avatar
Surgin is on a distinguished road
You can do it at home, use good parts or you will do it more than one time. Do both sides while you have the tools out.
Justin
Old May 5, 2011 | 10:40 PM
Sturg's Avatar
Yupp just do it at home, I (because I'm broke) just did one side and used the hub they sell at autozone and it worked out fine for me. I ended up doing the other side like 6 months later though lol. If you can afford it do both.
Old May 5, 2011 | 11:11 PM
Rottidog's Avatar
Drive at highway speed for 20 mins or so then pull over & feel the front rims near the center. If 1 side is warmer/hotter than the other then there's a good chance it is the hub bearing assy. that needs replacement.
