ignition coil and control module
Old Dec 30, 2011 | 04:38 AM
darknight's Avatar
darknight is on a distinguished road
Default ignition coil and control module
How hard is it to remove and replace an old ignition coil and control module?
Old Dec 30, 2011 | 08:34 AM
They share a bracket on top of the engine. Shouldn't take more than 20 minutes the first time through. Rivets have to be drilled out or cut off to get the coil off the bracket if its never been replaced before.
Old Dec 30, 2011 | 06:44 PM
darknight's Avatar
Ok kool.. thanks for the info
Old Jan 18, 2012 | 07:41 PM
darknight's Avatar
Can I just replace the coil or should I change both the coil and module at the same time?
Old Jan 18, 2012 | 08:29 PM
spittybays
Guest
Posts: n/a
Just wondering, why are you doing this? I think you can get them checked at a good parts store. I have had to change the module but never the coil, just luck I guess. Rivets are no sweat but there is a little pack of grease that comes with the module that you have to use. If it's not in the box give it back.
Old Jan 19, 2012 | 11:41 AM
darknight's Avatar
Because I reason to believe that my coil is going bad.. and yes its the original.. its never been replaced
Old Feb 6, 2012 | 10:17 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
took me twenty minutes .... quick n painless. new one looks nice and clean.. probably the only benefit.
Brian5792
Oct 24, 2018 11:34 AM
chrisblaze
Dec 17, 2009 12:34 PM
cannibal440
Performance & Brainstorming
Mar 18, 2008 10:47 AM
USMaverick101
Oct 31, 2006 03:10 AM
USMaverick101
Oct 29, 2006 10:29 AM
