Ignition switch problem ?
Old Apr 20, 2014 | 05:22 PM
  #21
Originally Posted by gpoteet71
Replaced ignition switch. Still no start.no power to half the fuseblock. Got fuel fire and 150 psi. On all cylinders compression.
I'm stumped. Replaced pcm. Still no power to half of the fuseblock.
What year, 2 door or 4 door, automatic trans or manual, ZR2, LS or LT?
Old Apr 20, 2014 | 05:43 PM
  #22
gpoteet71's Avatar
gpoteet71 is on a distinguished road
Neutral safety switch. Also I was 180 degrees out of timing.
Reset timing and it fired right up.throwing tcc codes now from new computer. Gonna put old computer back in and see what happens.
Old Apr 20, 2014 | 05:59 PM
  #23
If you leave the old PCM in the vehicle, you will need to have it flashed to your VIN and the crankshaft position sensor relearn must be performed. Both are mandatory, not optional. If you reinstall the original PCM, nothing needs to be done to it.
Old Apr 20, 2014 | 07:24 PM
  #24
gpoteet71's Avatar
thanks for the info captain, before buttoning up thedash, i pulled the ign. switch to make sure i was in the right spot. it wasnt. now it will start and die in a sec. gonna piddle with the switch some more to make sure im in the right tooth. tried the thirty minute relearn to no avail. security light is not on..........
mine is a 2001 2dr 4x4 ls ZR2 manual trans.
Old May 26, 2014 | 09:42 PM
  #25
DJBlac1927's Avatar
DJBlac1927 is on a distinguished road
Ok Im New To This But SOMEONE PLEASE HELP
I have a 2001 blazer xtreme i lost my keys then went on youtube and some other forums they said drill into the cylinder...well just as i was gunna do that my mother in law found my key..i went got it came home went to start it up and the damn thing broke right in half then i dropped it... long story short i driled into the cylinder i put my screwdriver in i get the door chimes i can put it in gear but the ignition WILL NOT TURN!!!! so i cant get the ignition out someone please help!!!!!! Thnx
Old Dec 26, 2017 | 01:09 PM
  #26
Tres08's Avatar
Tres08 is on a distinguished road
Default Solved
chased this problem 2 years, swapped ignition still no go. Found it just recently that new ignition was bad and not firing all accessory etc. Especially when cold. Try a command start, that bypasses everything from the switch.
Old Dec 26, 2017 | 03:17 PM
  #27
GeorgeLG's Avatar
To find out if an intermittent ignition switch is your problem, get your dvm out and connect it to either the input or output of the switch with a jumper lead and see what youve got when it dies. No power in then its not the switch. Good power in and no relevent power out then its the switch.
When part of the fuse block/dash/etc dies, please report which functions are lost which helps us find the fault.
George
Vandal6947
Feb 18, 2010 01:11 PM
Fozzy
Feb 15, 2010 04:21 PM
stevelknievel
Aug 18, 2007 04:30 PM
Bojib
Jun 21, 2007 12:28 PM
headache
Apr 30, 2006 12:47 PM
