Ignition timing issue
Old Feb 16, 2016 | 06:12 PM
odat's Avatar
before I'd suspect timing chain I'd guess dist. gear - one way to check chain for slack, with the dist. cap off rotate the crank pulley back and forth slowly and look for hesitation in rotor movement
A very minimal amount of hesitation movement I would suspect dist gear
Usually in my experiance major hesitation is needed for a chain is to be suspected
This test is not 100% accurate but a good base to start with
Old Feb 16, 2016 | 07:13 PM
Blazer Kid's Avatar
Blazer Kid is on a distinguished road
yeah im gonna go check it out, i was just gonna pull the distributor and rule it either the problem or out
Old Feb 16, 2016 | 07:37 PM
Blazer Kid's Avatar
no hesitation between crank and distributor rotor
Old Feb 16, 2016 | 07:39 PM
Timing chain not the problem.
Old Feb 16, 2016 | 07:56 PM
Blazer Kid's Avatar
there is the tdc mark on the crank, i rolled it and now i cant find it
Old Feb 16, 2016 | 07:58 PM
Blazer Kid's Avatar
where is it sorry typo
Old Feb 16, 2016 | 07:59 PM
Blazer Kid's Avatar
one of my friends had the 03 silverado with the 4.3 and she had a stripped dist gear. ended up changing everything out before they figured it out
Old Feb 16, 2016 | 08:01 PM
That's exactly why we're helping you diagnose the problem
There are two marks on the dampener, see post #5.
Before you remove the distributor: use a socket & ratchet and rotate the crankshaft until the dampener marks are aligned with the index marks on the timing cover, AND the rotor is pointed near the "6", (having the crank lined up is more important). While the distributor is removed, DO NOT move the crankshaft, or activate the starter, or you'll create more work for yourself.
Old Feb 16, 2016 | 08:58 PM
Blazer Kid's Avatar
scratch that, the guy that put it TDC used the wrong mark on the dampener so my truck is dead nuts time. so i have spark to all holes, 55 psi fuel pressure at the schreder valve and dead nuts time. cranks and backfires out the throttle body
Old Feb 16, 2016 | 09:07 PM
55psi is too low. Find out where the problem is:
https://blazerforum.com/forum/2nd-ge...eakdown-88305/
