Ignition timing issue
Old Feb 21, 2016 | 07:06 PM
  #31
Blazer Kid's Avatar
Blazer Kid is on a distinguished road
i had a battery with bad cells, problem solved
Old Feb 21, 2016 | 07:08 PM
  #32
Blazer Kid's Avatar
took my batt to get charged and tested, tested bad, bought a new one, installed it, runs like a top
Old Feb 21, 2016 | 08:02 PM
  #33
That doesn't explain posts #3 & 4, but glad you got her running
Old Feb 23, 2016 | 08:35 AM
  #34
Blazer Kid's Avatar
well not quite happy yet, i disturbed the distributor and had a funky idle, kept playing with it and fouled my plugs (went the wrong way with my distributor and flooded it) replaced the plugs, line everything up, it had a hard time starting and its throwing a p0300 and a p0135, any suggestions? its still got a funky idle, very inconsistent
Old Feb 23, 2016 | 09:24 AM
  #35
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
How does one disturb their distributor? If it had a do not disturb sign up, you should have known better....
For starters, I would think your cam retard is off. Are you sure it's a 135 and not a 1345 code? Do you have a scanner that can read the cam retard? If so, set it a 0 degrees ( +/-2 @ 2000 rpm ) tighten the distributor clamp down and leave it alone!!
Clear the codes, drive it around and see what codes come back...
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
chevcamls1
Dec 29, 2007 07:19 PM
