Initial timing 4.3
#21
yesi have spark at the coili think i know what i did after getting it to the compression stroke number 1 i turned the crank pulley by hand to line up the marks but i turned it counter clockwise because that mark was closest to the notch i should've turned the engine clockwise and i believe that was my mistake
#22
its alive
#24
For me on my what i believe is an 01 block the distributor will only go in correctly on TDC compression, If the marks are aligned on exhaust stroke it will be offeset by a tooth and wont line with the #6 mark. Either way if its running now then good stuff.
ChevOeat
10-13-2012 10:56 AM
