injectors
Old Nov 16, 2012 | 08:24 PM
jprisher's Avatar
jprisher is on a distinguished road
Default injectors
I have a 99 S-10 4x4 Blazer. I bought it as a repo and knew it had water in the oil but was betting on a blown head gasket. I lost, the motor was locked up. I got an engine from a salvage yard and it had a stuck valve, motor would not rotate all the way through. I had to get #2 motor. It turned out good but I have been fighting a miss. I replaced all new ignition components and still had a miss. Anyway it come down to injectors. I cleaned another set from the old engine in a ultrasonic cleaner. I cleaned the injector and poppet and blew them out did i mess them up. I was thinking about putting them in tomorrow.
Old Nov 16, 2012 | 08:29 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I dont think so at least I hope not cause thats how i cleened mine also.
Old Nov 16, 2012 | 08:45 PM
jprisher's Avatar
Default injectors
A lot of white oily junk came out of the micro filter where the fuel inters the injector. A couple plugs came out with out me knowing it between the 2 terminals when I blew them out. I am not sure what they were there for. It looked like they were poured in to prevent tampering. Anyway I put new o-rings on and cleaned the meter block put oil on the o-rings and put them in. I am going to try it tomorrow. Thanks for the reply. Have you run yours after cleaning.
Old Nov 17, 2012 | 10:30 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'.*
Old Nov 19, 2012 | 09:41 PM
jprisher's Avatar
Default cleaning injectors
Hey I discovered earlier today I can pull the poppet tubes off the bottom of the injectors and use a syringe and needle to put cleaning fluid in the tube and take a blow gun and shot about 70 psi and the poppet will pop and spray,cleaning out the poppet.John.
Ryan D
Oct 25, 2010 02:00 AM
jacsdad
Apr 20, 2006 02:00 PM
mregulater
Apr 3, 2006 01:07 PM
matt_87_s10_blazer
Jan 26, 2006 09:02 PM
mytruck2
Oct 10, 2005 12:45 AM
