Inline Fuel Pressure Tester
I'm going through the factory fuel system diagnostics, and I'm at the point where I need to connect a fuel pipe shutoff adapter and gauge on the fuel filter outlet. Can anyone recommend equipment for this purpose? Currently all I have is a standard fuel pressure gauge that fits on the test port under the hood.
Thanks.
Thanks.
Disconnect the supply line to the fuel filter and connect it to your pressure gauge.
If your gauge doesn't have the correct adapter(s) then you will have to hit the brass bins at your local hardware or auto parts store and come up with something that will work.
OhioLefty
01-20-2013 01:13 PM
zombiewoof
02-06-2008 09:13 AM
