what kind of fuel injection presure tester should I buy?
Old Feb 6, 2008 | 08:24 AM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default what kind of fuel injection presure tester should I buy?
I would like to have this tool in my box...I would only be using it to test my 2 blazers so a expensive multi-use tool is not required...Im looking online for them but Im unsure of the right tool....Hopefully its not too expensive...Any feedback would be much apreciated...Thanks
Old Feb 6, 2008 | 08:48 AM
Default RE: what kind of fuel injection presure tester should I buy?
For the Blazer's that you have, any typical tester would do. Its when you get into some other makes/models and/or TBI applications where you need a more expensive tester that comes with the appropriate fittings. I think my tester cost me $25... I just bought the cheaper one from Advanced Auto. And I've used it a LOT!
Old Feb 6, 2008 | 09:00 AM
zombiewoof's Avatar
thanks swartlkk, I work at an automotine parts stamping plant..I may try to put something together on my own...I wonder is a liquid filled guage with a adapter used for high presure nitrogen conection would work...
Old Feb 6, 2008 | 09:13 AM
A liquid filled gauge would work fine so long as it was meant for use with petroleum products.
I had posted the actual connection type and thread used in the fuel pressure test ports awhile back. Let me see if I can dig it up.
Here ya go: Fuel Pressure Gauge Adapter
er0ck273
Aug 19, 2014 01:38 PM
OhioLefty
Jan 20, 2013 01:13 PM
TheRandom1
Aug 16, 2011 11:05 AM
SlydinClyde
Oct 20, 2009 12:56 AM
Patrick_Boyle
Aug 21, 2009 03:28 PM
