Installing an Engineered Cooling Products Aluminum Radiator
Old Feb 20, 2021 | 05:38 PM
  #41
I wonder why mine didn't come with those threaded mounts.
Old Feb 21, 2021 | 07:08 PM
  #42
2001ZR2's Avatar
I am thinking about a rivet insert nut but the cover is about 1/4" wide and the hole is supposed to be 19/64"
Old Feb 21, 2021 | 07:12 PM
  #43
That's why I went with 1/8" rivets instead of nutserts.
Old Feb 22, 2021 | 12:21 AM
  #44
I like those rivet nut inserts but you only have so much room.
Old Feb 24, 2021 | 03:45 PM
  #45
2001ZR2's Avatar
A close up of the bracket
The fan mounted ...I will adjust to get the fan closer
I used rivet nuts into the fan shroud
Old Feb 24, 2021 | 03:56 PM
  #46
That looks like it's going to work pretty well.
Old Feb 24, 2021 | 04:58 PM
  #47
Very nice! Did you do the welding yourself? That is a skill I wouldn't mind learning someday.
Have you found a good thread or advice on how to hook up the fan wiring?
Old Feb 24, 2021 | 05:43 PM
  #48
2001ZR2's Avatar
I had a fab shop make the brackets for $40 and I used a fan controller and wire it up per the instruction off the battery and off of the fuse block under hood.
The fit of the fans is too tight right now need to why it it touching the water pump nose thread for the thermostatic clutch.
Old Feb 24, 2021 | 05:44 PM
  #49
2001ZR2's Avatar
Tom how tight are the fans to your engine?
Old Feb 25, 2021 | 07:16 AM
  #50
There's quite a bit of room.
