Installing trailer wiring
I got a hitch from the junk yard, now i need to get some wiring, sounds like there is a harness behind the bumper to get all the wires i need, is there a harness that plugs into the blazer to give me the 4 pin on the other side or do i need to cut into the wires and wire them to a 4 pin harness? 2004 4.3 4door 4x4
if you go to your local auto parts they might have a set already with a tee no need to cut wires or any thing
edit: something like this Just make sure it says the year and make on the box
![](http://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//874/large/6251544_hpo_40125_pri_larg.jpg)
SO there should be some sort of plug at the end of the factory stuff that i can plug that into?
yes there should be a some sort of plug in the harness so you can jump it like the picture shows
power would go into the trailer harness then jump out of the trailer harness to where ever its going
looking at the part stores online they just show a universal part witch cuts in and splices to the trailer harness, ill have a look under the blazer tommorow for the harness plug and see if i can get anywhere, thanks
its hard to find things online most stores dont have there whole inventory online
ill ask around tomorrow maybe the dealer will have something ill check there also. Thanks
phxjosh
10-30-2013 10:03 AM
AndrewO1991
02-19-2013 03:52 PM
blazermayne87
07-13-2009 02:15 AM
trapper_canada
08-15-2005 11:33 PM
