Instrument Cluster Problems
Old Aug 6, 2007 | 05:13 PM
DoubleSprings's Avatar
DoubleSprings is an unknown quantity at this point
Default Instrument Cluster Problems
I have a 98 Blazer and have been having Instrument Cluster problems for about 6 months now. First my digital PRNDL and Odometer display started blinking. Then my odometer stopped working, but the trip odometer still worked. Then the cluster would go crazy sometimes, Tach would jump and some of the lights would blink on and off. I bought a used cluster on Ebay, installed it and it was fine for a week. Gradually it started having the same symptoms. Now three weeks later it is the same as before. Any ideas? I have not replaced the ignition switch because I ckecked the voltage at the CLSTR fuse when the display was out and it was fine. The voltage at the CRUISE fuse was also OK.
Thanks
Old Aug 26, 2007 | 02:52 PM
Default RE: Instrument Cluster Problems
I still have not solved this problem, I have looked over the whole vehicle looking for a shorted wire of some sort. What is wierd is that I am not having any other prolems, the blazer runs fine.
Anyone seen a similar problem before?
Thanks
Old Sep 15, 2007 | 09:02 AM
MountaineerMama's Avatar
MountaineerMama is an unknown quantity at this point
I'm having the same problem. Would love to find out what it is.
Old Sep 15, 2007 | 03:03 PM
I found that the wire that comes off of the ground sie of the battery to the body was broke. I fixed it and now the problem is worse, the cluster goes crazy all the time now.
Old Sep 15, 2007 | 11:20 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
The only thing I can think of to make sure all the wires are connecting to the cluster properly and that the plug is not loose. Other than that, good luck.
Klone
Feb 19, 2011 06:34 PM
elementalnature
Mar 24, 2008 05:31 PM
error_401
Mar 17, 2008 06:39 PM
Russ57
May 14, 2007 01:43 AM
FJ40sRock
Mar 5, 2006 04:48 AM
