Instrument lighting problem.
Old Jun 27, 2010 | 07:26 AM
glued2it's Avatar
glued2it is on a distinguished road
Default Instrument lighting problem.
I searched and found similar problems, most of the threads i've seen have other topics that get more focus than the lighting problem.
I just bought a 2000 blazer yesterday, the gauge lights do not come on but everything works fine. I work the night shift and need to get this figured out quick. seems to be a common problem.
Old Jun 27, 2010 | 08:58 AM
glued2it's Avatar
I put a meter on the panel & interior lamp control switchand got varible resistance on a few pins. Not really sure how to check it thouroghly.
Old Jul 1, 2010 | 12:59 AM
glued2it's Avatar
I replaced the dimmer switch and everything worked fine for a few minutes. The brand switch is already burnt up. $40 in a blink of an eye!
I don't know what to do @ this point!
Old Jul 1, 2010 | 12:27 PM
glued2it's Avatar
I can't seem to figure out what caused the switch burn up so rapidly. If there was a bad ground, the switch would work intermitantly right?
The only I can possibly think of is a faulty ECM.
I work nights so this is a huge issue!
Anyone have any ideas?
Old Jul 3, 2010 | 06:04 PM
glued2it's Avatar
I just put in a fused jumper on the 2 outside green wires to bypass the dimmer all together.
Old Jul 3, 2010 | 08:12 PM
84BlazerS10's Avatar
Yes, if it was a bad ground the switch would work intermittently. I'm thinking there is to much of a current and that is why it keeps blowing out.
Charibdis
Feb 27, 2012 09:43 PM
n9ktw
Apr 20, 2011 06:58 AM
Hot Rod
May 13, 2008 01:43 PM
Russ57
May 14, 2007 01:43 AM
idr
Mar 13, 2006 12:33 PM
