Intake manifold gasket
I was looking at that, but rockauto said that it does not fit a 95. It is difficult to find the entire gasket kit including intake, valve cover, plenium,and rotor gasket etc. Can anyone else recommend the part number including all the above in a kit?
thanks,
bizzs
thanks,
bizzs
You stated 95 in your original post,then said 96 in a later post. Yes the 95 is different,but only in the ancillary gaskets(plenum) but you do not have to break apart the upper intake to do this job.I believe the actual intake to head gaskets are the same as are the Valve cover gaskets.The distributor gasket is the same as every small block from 1955-2005.All these gaskets are available in a set or separately:Fel-pro,Victor,Mr.Gasket etc. Buy your gasket set locally to avoid any headaches in the event of error!
kermit1112
20
Jan 21, 2010 11:20 AM
dunontme
Nov 17, 2009 11:04 PM
blazerdan
Jul 14, 2005 12:51 AM
