Intake manifold gasket
Old Aug 9, 2013 | 08:16 PM
bizzs's Avatar
bizzs is on a distinguished road
Default Intake manifold gasket
I have a 95 Blazer and the lower intake manifold is leaking antifreeze. Can anyone recommend what brand gasket kit set I should purchase, including valve cover gaskets?
Thanks
bizzs
Old Aug 9, 2013 | 09:35 PM
spittybays
Guest
Posts: n/a
Felpro is the gasket of choice around here.
Old Aug 9, 2013 | 10:40 PM
bizzs's Avatar
Thank you, I read that.. I could not find the entire gasket kit for a 95 blazer. Would you happened to know what the part number would be?
Thanks
Old Aug 10, 2013 | 01:15 AM
step66's Avatar
I used Felpro MS 95817 a few years back on a 96 4.3-Any quality jobber will be able to provide this...
Old Aug 10, 2013 | 08:08 AM
bizzs's Avatar
I was looking at that, but rockauto said that it does not fit a 95. It is difficult to find the entire gasket kit including intake, valve cover, plenium,and rotor gasket etc. Can anyone else recommend the part number including all the above in a kit?
thanks,
bizzs
Old Aug 10, 2013 | 09:52 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
definitely fel pro without question
Old Aug 10, 2013 | 01:25 PM
step66's Avatar
You stated 95 in your original post,then said 96 in a later post. Yes the 95 is different,but only in the ancillary gaskets(plenum) but you do not have to break apart the upper intake to do this job.I believe the actual intake to head gaskets are the same as are the Valve cover gaskets.The distributor gasket is the same as every small block from 1955-2005.All these gaskets are available in a set or separately:Fel-pro,Victor,Mr.Gasket etc. Buy your gasket set locally to avoid any headaches in the event of error!
Old Aug 12, 2013 | 07:57 AM
Lev_prav's Avatar
Lev_prav is on a distinguished road
I used FEL-PRO Part # HS9354PT4 for my 95.
Old Aug 13, 2013 | 12:53 AM
step66's Avatar
Right,but that is a complete head set, that is not required for the LIM gasket job.
Old Aug 13, 2013 | 09:34 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Lower intake manifold gaskets are different 92-95 from 96+. Different number and position of intake to head bolts
LJ809
Apr 25, 2010 06:02 AM
kermit1112
20
Jan 21, 2010 11:20 AM
dunontme
Nov 17, 2009 11:04 PM
kiliwizz
Jun 8, 2006 05:54 PM
blazerdan
Jul 14, 2005 12:51 AM
