Intake manifold gasket?
Old Feb 13, 2007 | 05:29 PM
99blaze's Avatar
99blaze is an unknown quantity at this point
Default Intake manifold gasket?
My intake manifold gasket has been leaking for about a month in my 99 blazer. I want to replace it asap. I know it is a big job, but I would like to try to accomplish it myself. Does anyone know where I could find detailed instructions on how to do this or if anyone could give some suggestions that would be great.
Thanks!
Old Feb 13, 2007 | 05:36 PM
4lowlife's Avatar
Default RE: Intake manifold gasket?
A haynes manual. Get some injector O rings from the dealer before the reinstall on the injectors. Permatex high temp copper silicone too. that helps for the corners. Might as well install a new water pump since you have to change the coolant and engine oil when you're done. Use tapeand label everying. fuel lines, vacuum, ect, I did it to the plug wires so I know where they go.
I did this while replacing the upper plenum on my '01 Impala. I did a post some time last year on this.
Old Feb 13, 2007 | 06:07 PM
99blaze's Avatar
Thanks, I appreciate it!
Old Feb 13, 2007 | 06:24 PM
I had found a how-to on the net a long while ago and have the PDF file that detailed it all out with pictures on my laptop, however, I do not have the link to the website where I found it on my work PC. I'll see if I can't dig that up for ya when I get home from work.
Old Feb 13, 2007 | 11:49 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
This LINK should do the trick for ya.....
Old Feb 14, 2007 | 12:31 AM
Yup, that's exactly what I have in PDF format. Hmm... I just couldn't find it.
Old Feb 14, 2007 | 02:25 AM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Is the intake manifold gasket a normal problem on these engines?It seems like on every other GM viechle either I or my family has owned it had this problem.
Old Feb 14, 2007 | 04:37 PM
joey's Avatar
joey is an unknown quantity at this point
YES this is a notorious problem with the 4.3sas well as many other GM V style engines. The job is fairly easy and doesnt require any special tools besides a tourqe wrench in inch lbs. I just did mine last weekend. From start to finsh I had the truck running in 5 hrs.
LJ809
Apr 25, 2010 06:02 AM
kermit1112
20
Jan 21, 2010 11:20 AM
dunontme
Nov 17, 2009 11:04 PM
kiliwizz
Jun 8, 2006 05:54 PM
blazerdan
Jul 14, 2005 12:51 AM
