intake manifold leaking very bad..i need help!
Old May 11, 2013 | 08:54 PM
kcullen's Avatar
kcullen is on a distinguished road
Default intake manifold leaking very bad..i need help!
i have a 2000 4wd blazer and i am tons of coolant from the bottom of my engine when it is running. i was told by someone that my intake manifold has to be cracked...does this sound correct and how hard and expensive is this to fix? thanks a lot!
Old May 11, 2013 | 08:59 PM
Not very common for the manifold to crack BUT, it is very common for the gaskets to leak. Best to pressure test the cooling system and find out for sure what's leaking. Most auto parts stores will rent/sell the tester.
Old May 11, 2013 | 09:31 PM
richphotos's Avatar
Also, Check your oil, and your coolant, coolant for oil, oil for coolant. until then, try not to drive it.
Old May 11, 2013 | 09:46 PM
kcullen's Avatar
is it common for it to leak that bad? as soon as you turn the engine on its like a shower coming out of the bottom of the enginge...
Old May 11, 2013 | 10:39 PM
richphotos's Avatar
You need to pinpoint where the leak is coming from, where is most of the coolant coming from, front or rear or side of the engine? Check all other things, water pump, radiator hoses, heater core hoses ect. Rule them out before you jump to the head gasket.
Old May 12, 2013 | 04:14 PM
LannyL81's Avatar
Sounds like what one of those chain auto repair shops would tell you....
Old May 14, 2013 | 02:18 PM
abig84's Avatar
ive never seen a s10 manifold crack but those crappy ones they put on the 4.6 fords, ive seen a few of those crack
Old May 14, 2013 | 03:26 PM
I agree, never seen one crack, seen plenty of them corrode though
strawhatmatt
22
May 20, 2013 12:02 AM
don1955
Apr 6, 2013 09:39 PM
iamchevyman5
Sep 22, 2012 05:59 PM
Epikos
Nov 30, 2011 09:24 PM
Lawayne
Aug 28, 2010 02:50 PM
