Leaking intake manifold?
Old Apr 6, 2013 | 03:59 PM
don1955's Avatar
don1955 is on a distinguished road
Default Leaking intake manifold?
Hey gang first time posting but have used this forum a number of times for information and for that I thank you. I have a 2000 chevy blazer 4wd with 163000 miles on it. My question does the motors in these trucks have an issue with intake manifolds leaking coolant? I have notice coolant on top of the manifold, have been loosing coolant for awhile now with no noticeable puddles under the car, no trace of water in the oil either.Thank you for you help.
Old Apr 6, 2013 | 04:02 PM
chris015's Avatar
usually its the lower intake gasket. Time to change it!
Old Apr 6, 2013 | 04:30 PM
Yup, VERY common problem for the OEM gaskets to leak. If you use the Felpro MS98002T gasket set, clean the gasket surfaces, chase the threads on the bolts and in the heads, use a medium strength thread locker on the bolts and follow the tightening sequence and torque procedure, they will not leak.
Make sure you adjust camshaft retard after you reinstall the distributor, (part of the job). It requires a scan tool capable of viewing streaming camshaft retard data.
Old Apr 6, 2013 | 04:53 PM
jaystoy's Avatar
jaystoy is on a distinguished road
Is this the same part number kit for the 94 4.3 Vin W as well?
Old Apr 6, 2013 | 05:48 PM
don1955's Avatar
Make sure you adjust camshaft retard after you reinstall the distributor, (part of the job). It requires a scan tool capable of viewing streaming camshaft retard data.[/QUOTE]
what types of scan tool allows viewing streaming camshaft retard data?
Old Apr 6, 2013 | 08:32 PM
Jay, 94 W intake gasket is MS95832, different design and waaaay cheaper.
Don, It requires a "high end" scan tool, the $500 el cheapo ones that the auto parts stores use will not access it.
Old Apr 6, 2013 | 09:29 PM
jaystoy's Avatar
[QUOTE=Captain Hook;577951]Jay, 94 W intake gasket is MS95832, different design and waaaay cheaper.
Don, It requires a "high end" scan tool, the $500 el cheapo ones that the auto parts stores use will not access it.[/QUO
Thanks so much. Does the adjusting of cam retard apply to the 94?
Old Apr 6, 2013 | 09:39 PM
No. Camshaft retard is only on late production 95 W engines with EDI ignition, and all 1996 and newer W and X engines.
strawhatmatt
22
May 20, 2013 12:02 AM
kcullen
May 14, 2013 03:26 PM
iamchevyman5
Sep 22, 2012 05:59 PM
Lawayne
Aug 28, 2010 02:50 PM
blazerdan
Jul 14, 2005 12:51 AM
