Interchanging front differential
Old Dec 31, 2019 | 10:15 AM
vernd33501's Avatar
vernd33501 is on a distinguished road
Default Interchanging front differential
I have a 99 Jimmy that I have diagnosed as having the front differential shift engagement mechanism to be bad. Rather than replacing the fork, collar, and gears, i’m just going to get a known working unit with a warranty. My question is, will a front differential from a manual transmission blazer/ jimmy bolt right up in my automatic transmission jimmy? The only difference I can find through my research is that the MT differential is steel and not aluminum. Thank you
Old Dec 31, 2019 | 03:00 PM
El_Beautor's Avatar
The front diff is interchangeable between the manual and automatic transmission. Generally, the iron front diff is stronger than the aluminum one, so if you off-road that may be a good option/upgrade.
Old Dec 31, 2019 | 10:18 PM
odat's Avatar
And match up gear ratios ......
Old Dec 31, 2019 | 11:20 PM
vernd33501's Avatar
Thank you for the information, I figured the two would be interchangeable, but wanted to check with folks that were more familiar and knowledgeable with these vehicles than I am. I’ve already looked up my RPO code and it is GU6, so i’ll find one with the same gear ratio as the rear end.
Frank Bukowski
Mar 25, 2019 03:57 PM
kickme005
May 25, 2010 06:47 AM
2002XTREME
Aug 17, 2009 07:56 PM
elementalnature
Dec 26, 2008 09:32 AM
