Interior ambient air temperature sensor
Old Oct 26, 2023 | 04:59 PM
Dobby's Avatar
Dobby is on a distinguished road
Default Interior ambient air temperature sensor
I inherited a 99 Blazer LS 4 door 2 wheel drive. It has the automatic climate control and the sensor over the driver seat is buzzing loud enough to be irritating. I’ve tried to find a new one and Chevrolet no longer makes them and there are none in their parts catalog. I found one in Canada but they don’t ship internationally, does anyone have any idea for a substitute or work around. It’s part number is
AC-Delco 15-51149 or Chevrolet 15756446. I’ve replaced the blend door actuator with the correct one and it’s still just blowing hot air. I don’t think the temperature sensor is the fix but it’s still not working correctly and has to contribute to the problem. Any help would be appreciated.
Old Oct 26, 2023 | 08:00 PM
You might have to get one from a wrecking yard.
If you feel comfortable doing it, perhaps you can open up the one you have and see if there is something you can fix, e.g., add a small drop of 3 in 1 oil to the fan?
I did look and stumbled on what looks to be a very similar part; 22834330. Perhaps it could work or you could swap parts from one to another, if you are comfortable experimenting and tinkering with stuff.
Good Luck
Old Oct 26, 2023 | 08:26 PM
Dobby's Avatar
I’m going to the local pick and pull to look for one. I’ll tear into the one I have and see what I find, sounds like 1 blade of a fan ticking every time it rotates. Thanks for the part number I’ll check it out.
Old Oct 28, 2023 | 02:08 PM
Dobby's Avatar
I have a cousin that is a redneck genius and he worked out a workaround. Got a toggle switch and soldered the blend door motor to it and I mounted it in the cover of where the 4x4 controls would be. Up is hot and down is cold. It took 6 seconds to go through the full range so I just have to make sure I don't push on it for too long.
Old Oct 29, 2023 | 12:36 AM
roddy's Avatar
roddy will become famous soon enough
Replace the fan.
Check electronic component suppliers on-line. Probably find one that close.
I oiled mine when 1st noticed it making noise. It's been good for 5 years.
Old Oct 29, 2023 | 10:17 AM
Originally Posted by roddy
Replace the fan.
That is good to know that a drop of oil can help as I have the same system.
Old Oct 29, 2023 | 12:19 PM
GeorgeLG's Avatar
This is great, made me smile.
George
wokeupgrumpy
Dec 8, 2021 11:46 AM
Camfrank227
Oct 17, 2017 08:40 PM
Northern Z7
Jun 4, 2014 06:36 PM
kbar25
Sep 18, 2011 08:59 AM
jojocarreno
Jul 1, 2010 07:30 PM
