Interior lights staying on....
Old 09-28-2010, 09:45 PM
matt92's Avatar
matt92 is on a distinguished road
Default Interior lights staying on....
Im pretty sure the reason for this is because of an ajar door, but every time i check, every door is securely shut, including my tailgate and back window. Anybody ever have this problem? Or do they know where the sensors in the door that say if its open are?
Old 09-28-2010, 09:55 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
its one of the door jam switches. mine has the problem with the passenger side rear, the front one are on the dash on the sides and the rears are mounted on the B pillar on the truck. usually if you spin it a few times (the little ****/button part) it will start working again.
Old 09-28-2010, 10:20 PM
matt92's Avatar
alright man ill check it out. thanks.
Old 09-29-2010, 03:07 AM
m3ch's Avatar
m3ch is on a distinguished road
if not that theres always that little switch in the back by the rear glass with that little light.......i sometimes forget to turn that off
idk if every blaxer has it lol i know mine does
Old 09-29-2010, 06:43 AM
The front door switches *may be* part of the door latch mechanism itself. There may be something in the ends of the dash, but they *may not* be connected to anything.
*Moving to 2nd Gen Tech* - tech questions are not appropriate for the General Chat section.
Old 09-29-2010, 12:09 PM
01vortec's Avatar
Umm, it's awful funny when I press those tabs in on the sides of the dash the dome light goes off. They are the switches.
Old 09-29-2010, 12:22 PM
Well, it turns out that we both may be correct... I reviewed the schematic. The passenger side is the dummy switch (or maybe just a plug). In my old '00, the drive side had the switch, but it wasn't wired into anything and there were no connectors anywhere to be found near it. The switch in the door handle/latch mechanism did it all and it worked as it should.
GM is anything but consistent in how they do this. Reading a bit more, you may have a very base model without the factory content theft monitoring which may be why your switch actually works.
Basically, if you look up at the switches in the ends of the dash and find that they are not connected to anything and there are no plugs nearby, do not be surprised!
Here's the schematics:
Attached Thumbnails Interior lights staying on....-2000_frtdr_switch_sch.gif   Interior lights staying on....-2000_rrdr_switch_sch.gif   Interior lights staying on....-2000_inadvertent_pwr_relay_sch.gif   Interior lights staying on....-2000_ctsy_lamp_sch.gif
TexasSeabee
10-13-2014 09:57 AM
01TrailBlaze
03-08-2014 07:54 PM
CRAZYBLAZER87
08-16-2012 08:50 AM
szls188
07-08-2011 08:17 AM
locoboy72
10-19-2010 12:37 AM
Quick Reply: Interior lights staying on....
