Intermediate Steering shaft. Help!
Old Jun 17, 2014 | 07:45 PM
Gmas95's Avatar
Gmas95 is on a distinguished road
Default Intermediate Steering shaft. Help!
I have removed the bolt at the bottom that tightens the rag joint to the steering gear input shaft. I cannot get the shaft to lift off the steering gear though. I have searched and it just says to lift shaft towards firewall and is should lift out, mine desnt move enough towards the fire wall to come all the way off the steering gear, what am i missing ?
Old Jun 18, 2014 | 11:30 AM
burned's Avatar
burned is on a distinguished road
Tried a pry bar?
You installing a Cherokee shaft?
how to remove the steering knuckle on a GMC sonoma - YouTube
Old Jun 18, 2014 | 04:03 PM
TZFBird's Avatar
TZFBird is on a distinguished road
It's a little tough. The grease gets old and dried out. Just pry a little with a large screwdriver or an actual pry bar.
Old Jun 18, 2014 | 08:41 PM
Gmas95's Avatar
I have pryed on it still won move enough, I am just trying to move it to put the exhaust manifold on.
Old Jun 20, 2014 | 03:43 PM
LannyL81's Avatar
Once you pushed it as far as you can towards the firewall...pull it the other way as far as it will go. Might try a spray lube on the shaft and then try pushing it again. Probably have to do this a couple of times to get it to free-up and go far enough.
PMeloy
May 10, 2011 03:37 PM
Hellraiser
Mar 24, 2011 05:06 PM
saxman_IN
Mar 17, 2011 05:09 PM
kpzrx
May 28, 2010 12:04 PM
SniperX13
Mar 16, 2006 09:57 PM
