Intermittant Horn
Old Aug 12, 2007 | 06:17 PM
2klt's Avatar
2klt is an unknown quantity at this point
Default Intermittant Horn
2000 LT. 4.6, auto 2wd, Horn works very seldom. I have noticed that if I moved the steering wheel up or down, sometimes, it will let it work the next push. But it seems that is getting less and less. I think that I have the problem in the switch but am scared to death of trying to remove the air bag in fear of either activation, or not being able to get it back together properly or whatever else might go wrong. I have thought many times of changing my name to Murphey.
Is there anyone that will take the time to detail for me the right way to remove the air bag on the steering wheel and whatever else I might not known to check and overlooked. I have the 3 vol. set manual, but in all that have not been able to find procedure to remove the airbag.
Thanks for anyhelp....
Old Aug 12, 2007 | 07:06 PM
Default RE: Intermittant Horn
If moving the steering wheel allows the horn to work, it almost sounds like you've got a broken wire in the steering column harness...
Old Aug 14, 2007 | 12:19 AM
2klt's Avatar
swartlkk>>
Moving it up and down... not like turning the wheel to change dir.
Old Aug 14, 2007 | 07:01 AM
Yes, this is how I understood your original post. If I had thought it was while turning the steering wheel, I would have suggested checking out the clockspring. Something may be wearing on the harness at the tilt joint.
BlazerBaby
Sep 25, 2010 06:20 PM
bludool
Aug 26, 2009 04:01 PM
freonchill
17
Nov 30, 2008 02:28 PM
gscrippler
Oct 5, 2008 05:57 PM
PINTO MAN
Jul 16, 2005 12:08 AM
