intermittant starting problem (fuel pump relay)
Old Feb 11, 2008 | 07:14 AM
freonchill's Avatar
freonchill is an unknown quantity at this point
Default RE: intermittant starting problem (fuel pump relay)
weekend bump
Old Feb 13, 2008 | 09:28 AM
freonchill's Avatar
2 day bump
Old Feb 13, 2008 | 09:45 AM
If moving the harnesses around temporarily fixes the problem, then you either have a broken wire or an intermitten connection on one of the pins under the fuse/relay center. There is no easy way to fix this. You have to dismantle the harness back as far as it takes and inspect the wiring. If you found a bent pin, it is possible that this is your problem.
There is no such thing as a relay module. The fuse/relay center basically has traces inside that run from the connector terminals underneith to the appropriate cavities in the top where you will find either a fuse or a relay.
Now, what pin did you bend? On the underside of the fuse/relay center? How did you determine that was the appropriate pin to bend? Do you have the appropriate wiring diagram?
Old Feb 13, 2008 | 11:24 AM
freonchill's Avatar
on the underside of the relay box there were 5 connections (or as i am calling them modules)
each of these had a 10 x 10 grid of holes that the pins from the underside of the relay box connected to.
when i first had this problem, my mechanic put a light on fuel relay wire between the fuel pump and the relay box (near the relay box) so i just looked @ the color of that wire (light brown) and then followed that wire to the connection (module)
see attached diagram (image)
i bent the curved connector (in the 'module') back-out so that it would make contact better
and then covered it w/ dielectric gel
ps - i dont know whats wrong w/ the attachment - you have to click on the image twice before it loads up so that you can see it.
Old Feb 13, 2008 | 11:38 AM
Hmm.. I'll have to look up the wiring for a '99 when I get home, but there are no BRN wires that have anything to do with the fuel pump on a '00.
Here is the fuel pump wiring diagram for a '00:
Old Feb 13, 2008 | 12:19 PM
freonchill's Avatar
it might have been grey - i just remember it was light colored - closer to white than brown (so it could have grey and i thought it was brown since i had a compact flourescent when i was looking @ it that night)
your diagram shows grey right?
(im not good @ reading circuit diagrams)
Old Feb 13, 2008 | 12:28 PM
Yes, gray is the color of the wire in the F1 location, connector C3 (red) under the fuse/relay center.
I hope that bending the connector does the trick for you, but I am not sure... Once those connectors are fully seated, even tweaking the wire loom shouldn't move the connection...
Old Nov 30, 2008 | 02:28 PM
patton78's Avatar
patton78 is an unknown quantity at this point
Bump this up... didstraightening that bent pin fix it?
i'm having a similar intermittent problem with my '95.
3D_Illustrator
Nov 13, 2015 01:46 PM
bludool
Aug 26, 2009 04:01 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
