Intermittent Airbag Light
thanks , thats good to know since i have radio controls on the wheel also. Do you have any cross reference numbers ? , it seam s there are some they say fit and the number is totally different.
I got a clockspring from a member one time and the connector/plug under the dash was different. I had to cut the wires and put my connector on it. I soldered and heat shrinked the connections/wires and it worked fine. You might have to do that. I also had radio controls. 2002 ZR2 Blazer.
**The wire cutting and changing plug was for the air bag and not the radio.**
Since I can't post anything new, guess I'll post here.
Had my airbag light on and steering wheel volume controls not working, so after checking continuity in all my wires, I found my clockspring to be bad. Sure enough, ribbon cable is sheared off. Attempting to repair since I'm having a hard time finding a new or used one. Wish me luck. Hoping it will fix the airbag issue...
Just this morning I just unplugged and re-plugged the airbag sensor (Front LH) and the airbag light is gone! Maybe some corrosion or something in there. Just slid it out and in a few times to re-establish solid connection. I had an intermittent issue, driving it would go off and then stopped it would come on only sometimes though. Also when you revved the engine in park it would pop on and then go off. Same code 0036.
Jonboy
Mar 12, 2012 07:08 PM
aaronjohn20
Mar 21, 2008 07:00 AM
