Intermittent Spark
Old May 9, 2018 | 07:42 PM
4XBlazerSLT's Avatar
4XBlazerSLT is on a distinguished road
Awesome, it just sounded odd to me. Compression test is next on agenda. Slowly Blazer is running a little smoother each time I effect these repairs, so close to back purring like a kitten
Old May 10, 2018 | 01:25 AM
Mike.308's Avatar
So, if I understand You right, You seem to have a misfire symptoms on a random cylinders, not the specific one...?
If the spark is intermittent on the other plugs as well, it may be the coil or an ignition module too.
Old May 10, 2018 | 01:29 AM
Strange happenings, replaced tune up components and cylinder 4 misfire showed up. Changed rotor, then plug in #4, started random misfires (P0300) so put the other rotor back in (AC Delco) and reverted back to cylinder 4 misfire
Old May 23, 2018 | 09:57 AM
Update, replaced a sloppy distributor that had too much play in rotor as well as vertical play. Completed compression test and found 0 PSI in cylinder 4. Pulling valve cover and head to repair. Thanks for all your help with this
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
84blaze
Jun 4, 2012 08:24 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
