General part question
Old May 12, 2018 | 04:26 PM
1stchevy's Avatar
1stchevy is on a distinguished road
Default General part question
On my 2000 chevy blazer ,what is the part on the passenger side front of vehicle and directly under the radiator?There appears to be a broken vac line on it.Where does that line connect to?
Old May 13, 2018 | 12:30 AM
Have you tried tracing it to an end that is still connected to something?
Old May 13, 2018 | 07:02 AM
rockp2's Avatar
If it's under your battery and looks kinda like a flying saucer, it's the vacuum actuator for your 4wd. It locks in your front axle.
Old May 21, 2018 | 10:16 AM
LesMyer's Avatar
On my 2001 there is the A.I.R. pump and solenoid/valve down low right next to the idler arm, between it and the oil filter adapter. On mine there is one vacuum line to the electrical solenoid, then a line from the electrical solenoid to the vacuum operated valve. I just replaced mine a couple of months ago and the AC Delco replacement kit relocates the A.I.R. pump inlet and the electrical solenoid to up high next to the top of the radiator in order to keep moisture out (and subsequently locking up the pump). There was a tech bulletin on it. Not sure if 2000 has the same A.I.R. system though...... Do you have the check valves at the front of each exhaust manifold? If so, I bet it's the A.I.R. system in some form. My pump/solenoid/valves were 2001 only.
OK I looked it up and yours should be similar to mine.
Here's the diverter valve
https://www.rockauto.com/info/154/DV...mary__ra_p.jpg
Old May 23, 2018 | 10:34 AM
Tajohns34's Avatar
The 2000 does have it. Mine kept throwing a CEL and blowing the fuse. I pulled it off an it was full of water. I got a replacement from a junkyard and haven't had any issues since.
spider21
Nov 17, 2011 06:27 PM
98Ltblazer
Apr 11, 2010 11:34 PM
qquake2k
Dec 30, 2007 12:26 AM
FImports
Dec 20, 2006 09:13 PM
WDRacing
Engine & Internal
Nov 21, 2006 11:48 PM
