jounce bumpers
Old Oct 21, 2010 | 05:50 PM
blazerJim1701's Avatar
blazerJim1701 is an unknown quantity at this point
Default jounce bumpers
I noticed that the bumpers, the ones that bolt on the upper control arm, are hollow and the drivers side is completely off.
Question is, how do I replace them with out removing the upper control arm.
The little nut I can put a wrench on it but cannot get enough clearance to move the wrench to remove the nut to replace it.
Old Oct 21, 2010 | 06:01 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
Well you should be able to. The only way I could do mine when I put the new ones on was like a half a turn at a time with an open end wrench, talk about a royal pain. However if you have a gf thats more than happy to get the chance to help you work on your truck (like mine ) Then that's the perfect job for her. It takes patience which is something I come up a little short of. It's a pain, but it can be done
Old Oct 21, 2010 | 08:31 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Much easier to undo the upper 'A' to do this. I have done it both ways, many times but...the way to do it is to undo the upper 'A' frame-word to the wise-check out your upper ball joint before you do this just in case while you're in there you need to do that-never would be easier...Jerry
ekiMMike
Dec 6, 2009 11:52 PM
amazinnblazin
Oct 13, 2008 06:30 PM
98BlazerLT4x4
May 4, 2008 11:37 AM
19BLAZER96
Mar 28, 2008 10:44 AM
muszyngr
Mar 24, 2008 08:51 PM
