Jumping a side post battery
Old 05-10-2020 | 12:19 PM
puttster's Avatar
puttster will become famous soon enough
Default Jumping a side post battery
Even though I have cables with side post teeth, i can't seem to get a good grip on that tiny battery terminal nut. I was thinking about slipping a cable terminal lug in between the existing cable terminals and clamping on to that when using jumper cables. Question is, will I get enough metal to metal contact at the bolt holes?
Old 05-10-2020 | 01:02 PM
I wouldn't. It makes it easier for battery acid, etc. to get in there and cause corrosion. I would use a longer bolt and put a spacer on the outside of the terminal instead. Or use some of those extended terminals designed for adding winches, amps, etc.
Old 05-10-2020 | 06:14 PM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
When it comes time to replace your battery you could get one that has both side posts and top posts. That's what I did.
Old 05-10-2020 | 08:34 PM
This
Makes for a good place to wire up accessories to as well, like the aforementioned winch and stereo stuff
Old 05-10-2020 | 10:26 PM
puttster's Avatar
Damn. Where were you guys six months ago when I bought a three year side post battery?!
Old 05-11-2020 | 12:58 PM
sorry... I'm on and off active on the forum these days...
Old 05-21-2020 | 03:54 PM
puttster's Avatar
I got a pair of extenders similar to Tom A's pic. Thanks, all.
Edit: I put 'em in, next day I needed the jumpers. Brilliant!
Old 05-24-2020 | 12:39 PM
93S10TahoeLT's Avatar
Same.
Life gets in the way and it is hit and run on the forums..
Old 12-04-2023 | 12:28 PM
puttster's Avatar
I did get this side terminal setup two years ago. Blazer wouldn't start for me yesterday. After recharging, I checked metered the terminals and weirdly the original brass terminals read 12.54v but the extension nuts read 11.54v. I sanded the nuts down and did a little cleaning on the + terminal connector and got a re-read at 12.54v. I still don't trust it though.
I think the problem lies in the connectors but they are not easy to clean. Suggestions welcome.
Old 12-04-2023 | 04:27 PM
El_Beautor's Avatar
You could try cleaning them up really good to take off all the corrosion, and then coat them with dielectric grease.
Quick Reply: Jumping a side post battery
