K&N Intake
I'm going to be buying a K&N Intake for my '96, any tricks or advice for install or more HP gain??
Thanks in advance.
Thanks in advance.
Advice: Get an AEM Brute Force instead.
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
x2, skip the oiled filter. Many have run them without issue, but when you can get comparable gains out of a dryflow filter and not hassle with washing and re-oiling, why not?
Plus the AEM filter is larger, and the top of the intake actually bolts on instead of using hose clamps... so it won't pop off like the K&N does.
But doesn't AEM run an aluminum pipe which heats the air due to the engine heat, unlike the plastic of the K&N?
At the speed the air is going through the pipe... no it won't heat it up anymore than it already is. Couple that with the fact that the AEM filter is 50% larger than the K&N, and any air that is minimally heated up by the aluminum will be easily overcome by the volume of air coming in.
The gains claimed by AEM are 10.9 ft-lb Tq @ 5250 RPM and 11.3 hp @ 5500 RPM . K&N claims 7.42 hp
K&N Dyno:
http://www.kandn.com/dynocharts/57-3017.jpg
AEM Dyno:
http://www.aempower.com/images/produ...5D_4-3L_hp.pdf
http://www.aempower.com/images/produ...5D_4-3L_tq.pdf
K&N Dyno:
AEM Dyno:
I installed my k&n fipk last weekend, and love it! the install was real easy, no problems. i was planning on doing a how-to write up, but my camera battery died half-way through the install...the kit comes with a great guide w/ pics anyways.
i can definitely notice the sound difference, as my friend back home had the AEM, and this sounds quieter than his. I'm guessing it's the abs plastic vs. aluminum that changes the sound. There was a noticeable increase in throttle response after the install as well, since that stock box was awful for airflow.
I'll get some pics up tonight...
It's the size of the filter that changes the sound. The K&N only has a 6" long filter, while the AEM has a 9" long filter.
Sorry Jigg I'm going to go with the K&N because they have a better reputation, and I'm getting a good deal on it also. I dont mind about the sound, and I dont really mind about losing a 3 HP difference between the two. But I am also thinking about getting a good high-flow muffler or a cat-back system if you could recomend any? Keep in mind I'm in So-Cal and the cops can be strict about sound.
It's your choice... but the K&N actually has a pretty bad reputation is the s-series community.I've been on the s-series forums for the last 6 years... so i've heard quite a few times about how aggrivating they are to people, and how much of a pain in the butt it is to have to clean off the mass airflow sensor after the oil cakes it up and makes your mileage/performance take a dive. I personally own an AEM Brute Force, but i did have the K&N before, and sold it pretty much right away.
For exhaust, Magnaflow 18" is my choice. Sounds great, not ridiculously loud or raspy... stainless steel, lifetime warranty.
