K&N intake install, Trouble codes PO101,PO113
Old Nov 9, 2009 | 09:26 AM
  #21
electroman86's Avatar
electroman86 is on a distinguished road
That secondary air flow thing is your secondary air pump. It is for emmisions. GM wasn;t thinking right when they put the air tube for that pump. They put it down under the engine and when water gets in there it burns out your secondary air pump. You have to get a new secondary air pump and rerun the hose for it to the top of the engine. This is a pain in the but. I had to get it replaced twice. It cost me 500 clams to get it down the first time. Its a pain and expensive and pointless. But a must cause of that light. All it does is make your emmsions cleaner. Thats what that secondary air flow code is, trust me.
Old Nov 10, 2009 | 11:04 PM
  #22
gmc004x4's Avatar
gmc004x4 is on a distinguished road
look there is nothing wroung with k&n. it is smoething simple. put the old set up back on and see if the problem goes away. if it does try the k&n again. make sure your mass airflow senor is going the correct way. check all your wires again. i am telling you it is something simple
Old Nov 11, 2009 | 06:26 AM
  #23
There actually is something wrong with K&N (and all aftermarket oiled air filters). The oil that they use comes out of the filter and contaminates the MAF and IAT sensor. You may be able to clean the sensors though, but the trick is to make sure that the filter is not over oiled. Most are over oiled out of the box.
nharner
Nov 20, 2011 10:10 PM
wayneaaron
Aug 30, 2010 10:12 PM
rockon_79_54
Aug 19, 2008 05:27 PM
Bigblock396
Jul 18, 2007 09:49 PM
drperry
Jul 4, 2007 04:25 AM
