ka jerk
Old Sep 11, 2011 | 04:27 PM
zr2dan's Avatar
zr2dan is on a distinguished road
got this weird litlle jerk at a constant cruise speed it dont do it while i accelerate but just at a constant speed and rpm if hit the gas the power seems normal oil and temp gauges are normal and once i came to a stop it almost died once when i got to my driveway it seemed normal
bump^
Last edited by swartlkk; Sep 11, 2011 at 08:33 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 11, 2011 | 08:32 PM
Sounds like torque converter shudder. I had a more thorough post typed up, but saw your bump and figured I'd leave you to hunt for the info.
Please do not bump a post unless you have waited at least 24 hours as the rules of the forum require.
Old Sep 11, 2011 | 09:10 PM
AJBert's Avatar
I had the same thing about a year ago. Ended up doing several different things at the same time and it has not come back.
From what I recall...
-clean MAF
-Seafoamed
-replaced cap and rotor (brass contacts)
-fuel injector cleaner (Lucas)
-fuel filter
And maybe another couple of three more minor maintenance items. One or a combination of two or more fixed the problem.
I thought it might have been the torque converter and really didn't want it to be so I tried a few other things to eliminate anything else first.
Old Sep 11, 2011 | 09:15 PM
Torque converter shudder can be caused by many different things. The MAF sensor has been the #1 cause in my experience. If left go too long, it can either wear out the clutch in the converter, or blow the TCC solenoid.
Old Sep 11, 2011 | 09:31 PM
zr2dan's Avatar
can mass air flow be cleaned or just replaced sorry about the bump but a fresh post on topic takes it to the front page of the forum where its more noticeable again i apologise for the impateints
Old Sep 11, 2011 | 09:36 PM
xgiovannix12's Avatar
it can be cleaned like ajbert stated
Old Sep 12, 2011 | 11:39 AM
zr2dan's Avatar
today i have also noticed black suet around the tip of my exhaust i have a pcm for less tune with the rear o2 deleted as well as the egr sensor and i have a ses will a dtc code reader still read a custom tuned obd2 and also i smell a fait smell of gas could my spider injection be the culprit
Old Sep 12, 2011 | 12:08 PM
A tune doesn't change the basic OBD2 structure of the PCM, it just changes what codes are valid to trip.
Clean the MAF sensor and see what that gets you.
Old Sep 12, 2011 | 12:25 PM
zr2dan's Avatar
thanks klye i found a nice how to thread on the cleaning so i will give it a shot tonight after work looks easy enough/ well i cleaned the maf sensor and went for a nice drive didnt have any jerk at any cruising rpm or speeds and seems like it ran a little smoother
marlboro124
Oct 6, 2011 12:21 PM
Denominator
Oct 13, 2010 01:33 PM
steve8650
Feb 5, 2010 05:42 AM
derby66
Jul 2, 2009 08:17 PM
mikol23
Aug 11, 2008 06:58 AM
