Key issue
Old Jul 8, 2009 | 02:30 PM
Sorell's Avatar
Sorell is an unknown quantity at this point
Default Key issue
Hey everybody,
how does the key ignition work with the blazers. I have no problem starting or anything but for the past month or so when I go to remove the key it won't turn all the way back and stops in the on position for a couple minutes then I can tub the key the rest of the way and remove it. Anyone had this happen to them and/or know a fix?
Thanks
Old Jul 8, 2009 | 06:42 PM
Sounds like a problem with the lock cylinder and/or the shift linkage sticking. What happens if you wiggle the shift lever around while trying to remove the key?
Old Jul 8, 2009 | 10:56 PM
Sorell's Avatar
Ya tried wiggling the shift lever doesn't work. Its just the key being gay waiting a couple minutes or sometimes it works just fine. Sucks
Old Jul 8, 2009 | 11:32 PM
okvortec's Avatar
Is or has your security light on the dash been on recently?
Old Jul 9, 2009 | 01:52 PM
Sorell's Avatar
No, I've never had the security light ever come on actually. I think I need to replace the cluster though cause i have never had a 4wd light, washer fluid, a couple others had never come on... And my odomerter went out recently too haha. Would the security hold the key in for some reason?
Old Jul 9, 2009 | 02:09 PM
okvortec's Avatar
If a security light is on there is a good chance the ignition switch is failing. That could be tied in with the key issue. THe light itself wouldnt hold the key in, but a bad swtich might. I'd go ahead and replace the cluster so you know if your truck is trying to tell you something (but you can't see it due to a bad cluster.)
changeme20
Oct 24, 2020 02:12 AM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
whiteman_01
Jul 15, 2009 10:43 AM
