Keyless entry
My Chverolet Blazer has this immobiliser problem and the only people that i know that are able to do EU spec cars are based in Manchester England. It is not possible to programe new remotes to the EU cars. VERY VERY VERY expensive fault. I feel for anyone that has a Blazer with this fault.
I have, or rather my partner has
The procedure to program the remote is as follows-
Hold down the door unlock switch on the driver's door.
Turn ignition key ON - OFF and again ON - OFF.
Release the driver's door switch.
The doors should lock & unlock which shows the system is in the programming mode.
Then hold down both the lock & unlock buttons on the remote until the doors lock & unlock.
Turn ignition key ON.
If all is working right the system should work fine. You do not have to go to a GM dealer. If you need a new remote Ebay is a good source.
Make sure the doors of the vehicle are closed when you are doing this. All of them. Even the hood. If the security light flashes, it is not going into the proper mode. If when you let go of the unlock button, the doors don't lock/unlock, it is NOT in the mode, and will NOT accept new pairings of remotes.
Blazer keyfob
The key fob is programed as per other post,s: however the UK Blazers have a dual anti theft system that only Bauer Millet can overcome properly. It is costly procedure but they (Bauer Millet) are very good and your car will be perfect when it comes back. My Blazer workss fine since the repair was done. I hope this helps.
93Miata
24
11-14-2005 10:09 PM
