keyless remote
Old Apr 8, 2008 | 06:02 PM
jkr831's Avatar
jkr831 is an unknown quantity at this point
Default keyless remote
Hello all, I have a question about converting a Blazer with power door locks toa remote keyless entry system with GM parts from a salvage vehicle? Can this be done? Is there a pigtail somewhere under the dash that all you have to do is plug in a module then program remotes? If so where is it located? Thanks for any help.
Old Apr 8, 2008 | 06:04 PM
Default RE: keyless remote
What are you driving? Once I know that, I'll be able to make some suggestions. I'll also be able to move this post to the more appropriate forum section. Thanks!
Old Apr 9, 2008 | 12:18 AM
jkr831's Avatar
It's a 2001 4-door Blazer Kyle.
Old Apr 9, 2008 | 07:00 AM
Alrighty then.
*Moving to 2nd Gen Tech*
The RKE module sits on top of the lower kick panel under the driver side dash (above the pedals). It will attach to the kick panel itself just behind the Data Link Connector (DLC):
If the wiring is there, it should look something like this:
Old Apr 9, 2008 | 07:24 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
do you know for sure that your Blazer did not come with keyless entry allowing you to just program fobs? JP[&o]
Old Apr 9, 2008 | 07:56 AM
You could either check for the RKE receiver module as shown in the pictures I posted or the RPO code label on the inside of the glove box for AU0 (A U zero).
Old Apr 12, 2008 | 10:30 AM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
is this the same for a 97?
ComputerNerdBD
Oct 16, 2011 06:10 PM
lemon blazer
Dec 30, 2007 09:31 AM
times
Mar 8, 2007 02:18 PM
terriosouthstar
Dec 17, 2006 10:17 AM
cragpretzel
Nov 28, 2006 11:52 PM
