Knock on start up
Old Nov 28, 2013 | 10:59 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
It may or may not make difference since your engine balanced internaly by the balance shaft.My concern would be balancer coming apart if theres seperation between the rubber and and metal disk that makes the balancer.I have rebuilt alot of engines I never used a balancer that wobbled.I would do a google search and see what info you can find out.One thing that could happen is you can cause an oil leak
Old Nov 28, 2013 | 09:22 PM
LannyL81's Avatar
If the outer ring of the balancer is moving...it needs to be replaced. The outer ring will bounce around and could very likely mess-up other things.
Is the engine still under warranty? If so, makes me think the mechanic/friend does not want to do a warranty (free) repair.
Old Nov 29, 2013 | 03:28 PM
Other things like causing the crankshaft to be out of balance which can also cause the engine to start knocking.You said its been like that for about year I believe,Im surprised that no dame has occured already.
fredguaz
Dec 11, 2017 08:11 AM
98blazin
Oct 22, 2011 04:05 PM
JSPARKS913
Apr 7, 2010 03:43 AM
ejschultz
May 23, 2009 04:15 PM
kwacasey
May 5, 2009 04:48 PM
