Knocking noise when hitting bumps
Old May 9, 2008 | 01:46 PM
bobbyj42's Avatar
bobbyj42 is an unknown quantity at this point
Default Knocking noise when hitting bumps
I have a 2001 Blazer 2dr Rear Wheel Drive... Whenever I hit bumps, I can hear a knocking noise in the passenger side near the firewall. The ball joints on that side have been replaced. I simply cannot figure out what it is. Any thoughts?
Old May 9, 2008 | 04:14 PM
WolfPack's Avatar
Default RE: Knocking noise when hitting bumps
Control arm bushing?
Old May 11, 2008 | 10:43 PM
leeps's Avatar
leeps is an unknown quantity at this point
I had that same problem with my '02 Blazer. I would hear the noise on small bumps and when applying the brakes, right on the passenger side like you have. Since years ago I had a similar problem and replacing the badshocks solved the problem back then,I replacedminebut the annoying knock persisted. Eventually I found out the problem was the idler arm. I replaced it and the knocking stopped, almost completely. I had warped front rotors so I replaced them too and now it no longer knocks. I hope this helps.
Old May 13, 2008 | 12:45 AM
obso's Avatar
obso is an unknown quantity at this point
Check the torsion bar mount also. Had one go out on a 92 jimmy and it sounded like hell. Replaced the entire front end before someone mentioned that mount.
02Goldie_Loks
Oct 29, 2015 10:08 PM
dbleobarbie
Nov 15, 2013 11:39 AM
Nick Bain
Feb 25, 2009 03:58 PM
daxsteel
Nov 9, 2008 09:44 PM
blazergirl15
Jul 9, 2005 03:26 AM
