2000 blazer clunking when hitting bumps
Old Nov 15, 2013 | 11:25 AM
dbleobarbie's Avatar
dbleobarbie is on a distinguished road
Default 2000 blazer clunking when hitting bumps
Hey guys. So I have this loud clunking sound in the front end, both passenger and driver side, whenever I hit a bump, even when going over uneven pavement. My truck also seems to be very bouncy (swaying back and forth) I just had my front shocks and front wheel bearings replaced so I know those arent the culprits. Any ideas? Im trying to get ideas as to what it could be so I can get prices. Thanks.
Old Nov 15, 2013 | 11:28 AM
DesertStorm's Avatar
check your sway bar end links.. they have rubber bushings in them that rot over time and will cause exactly what you are describing
Old Nov 15, 2013 | 11:32 AM
Very cool, thank you so much. Thats exactly what my husband said, but hes the type who thinks he knows everything, and is usually wrong lol.
Old Nov 15, 2013 | 11:39 AM
Jakeduece's Avatar
Jakeduece is on a distinguished road
I second the sway bar end links. One of mine is in bad shape and in need of replacement. It is causing that very same issue as you describe. Not expensive to replace yourself, but you may end up cutting out the old one. Afterwards it should ride great!
A great way to make sure that the end links are bad is to watch them as somebody bounces the truck.. If they are bad, you'll see play in one or both. They shouldn't move at all if they are good.
musclecar70sfan
Nov 7, 2010 08:48 PM
Mytara12
Apr 27, 2010 10:13 PM
BrokenBlazr
Feb 26, 2009 08:16 PM
daxsteel
Nov 9, 2008 09:44 PM
bobbyj42
May 13, 2008 12:45 AM
