Labored Starter/Timing
Old Mar 26, 2012 | 08:39 AM
spittybays
Guest
Posts: n/a
Default Labored Starter/Timing
Have a starter that on cold start works perfect. After warm up, first turn of key motor sounds locked, second turn of key spins fine. It has been mentioned to me that a timing issue may cause this. Possible? If so advance or retard. All electrical seem's to check OK......Thank's, also if this is the case and anyone has time a short expaination.
Old Mar 26, 2012 | 09:24 AM
pettyfog's Avatar
Absolutely can be a timing issue. Base timing too far advanced . So the fuel/air ignites before absolute TDC, stalls the starter and cyl stays under very high pressure a while
But do you have obdI? Can you adjust timing? Otherwise it's an ignition fault somewhere.
Weak starter/battery resulting in low cranking speed will do same thing without actual ignition.
Caution: also a sign of hydrolock due to blown gasket. Look close.
Doctorvette
Nov 5, 2012 11:57 PM
bigkeith11
Dec 15, 2011 10:04 AM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
