Leak after fuel pump replacement
Hey, I think I may have pulled a stupid move and put the vent line on the return and vice versa. Is that even possible? I had a really hard time getting the 'return' line back on.
I know they are all diff sizes, but I'm pretty sure that's what I did.
When I run the truck after a little bit the vent solenoid? starts pouring fuel out and I can hear the vapour canister draining!
If anyone can just IM me that'd be awesome, it's raining out, I need another e-test and have to renew my plates ASAP.
The purge canister is designed to handle fuel vapor only. If/when it is subjected to raw fuel, it must be replaced. It will start setting EVAP DTC's and when you e-test, they'll find it, and the vehicle will fail. They're easy to install and only run ~$100.
Same thing can happen if you overfill the fuel tank, mainly in the Summer. Cold fuel comes out of the ground, vehicle parked on a 120 degree parking lot, fuel expands, floods the canister.
dj00140
03-14-2011 09:42 PM
ned4spd8874
02-10-2011 10:48 PM
nutdriver58
06-27-2010 01:25 PM
benshuey
06-19-2010 05:22 PM
cide
11-07-2009 01:26 PM
