LED Light Bar
Old 12-07-2009, 08:02 PM
Boyer2011's Avatar
Boyer2011 is an unknown quantity at this point
Default LED Light Bar
Hey guys i need some help. i just recently bought a new LED Light Bar and it has white LEDs for the reverse light. except i cant get them to work...im trying to hard wire them intot he reverse lights in my tail lights but cant get them to work...help!
Old 12-07-2009, 08:22 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
If you're trying to go right into one of your rear lights the reverse lights have a 2-wire connector. Backup lamp is lt. green & black ground. Look for a ziptied harness on the crossmember underneath the rear of the truck. If you have the trailer wiring harness it'd be easier.
Old 12-07-2009, 08:29 PM
Boyer2011's Avatar
ok well to wire the brake, R and L turn, and running lights i used the trailer wiring harness. so i used 4 out of the 6 wires. there were 2 wires left over but the directions didnt say to use them.
Old 12-07-2009, 08:35 PM
RonJon's Avatar
Well, if you have the light green there use it. If the leftover is a dark blue it's there in case you wanted to run electric brakes back there someday.
Old 12-07-2009, 08:40 PM
Boyer2011's Avatar
ok ill check out which wire is left over
Old 12-07-2009, 10:45 PM
old skool luvr's Avatar
since when did these Blazer's come pre-wired for an electric brake controller?
Old 12-07-2009, 10:49 PM
For the 2nd gens, if you had the tow package, you were pre-wired for a brake controller and 8-pin trailer plug.
Old 12-07-2009, 11:09 PM
really? my truck has the factory tow package on it, but i just ran my own wiring since i never knew there was any already there.
where is the wiring under the dash? specifically the thick dk blue for the rear feed?
good to know for the future S series i'll more than likely end up buying.
Old 12-07-2009, 11:24 PM
RonJon's Avatar
I dunno about "thick". Depending on what you're hooking up I have a feeling you did a good thing running your own wiring. To be honest I've never taken my own harness apart to look at it, I just splice a new 4 wire plug on every two years it seems.
Old 12-08-2009, 12:07 AM
yeah, i run a 7-pin plug, and always take it apart every Spring to inspect for salt damage. Ontario lives on a high diet of salt for the Winter-too many damn idiots on the road to use just sand like out West. i know our weather in Ontario isn't nearly as cold as out West, but it sure would be nie to not have white stains on the carpet/floor mats all the time.
Quick Reply: LED Light Bar
