LED turn signals = a few issues (not hyperflash)
ok before the comments all start on legal, "why", etc. understand this is not the first time i have done LED conversions I like them that's why I choose to do them and figure out these issues. I changed all the interior courtesy lighting over to soft white LED's as opposed to the normal cool blue LED's that most people use. Then i moved on to exterior lighting here is what is going on:
for Christmas i got clear parking lamp housings LED flasher relay 2x 3157 LED switchback bulbs, these exact ones - 2X 3157 60SMD DUAL COLOR SWITCHBACK WHITE AMBER TURN SIGNAL LED LIGHT BULBS 3057 for clarity parking lamp = housing under the headlight, no fogs in my case corner marker = amber bulb in headlight fixture. I installed them this afternoon and everything seemed fine until I turned the headlights on once I turn the parking lamps or headlights on both of the turn indicators in the cluster turn on just slightly dimmer than when the blinker is on. when you turn the blinker on you can see it get noticeably brighter then operate normally until the blinker shuts off then they go back to dim. I figured this had to have something to do with the relay so i went back to oem with no change. On a guess i figured there was a shared ground between the parking lamps and the corner markers. I pulled the corner marker bulbs and that fixed the cluster lights. since i am guessing somewhere on "the road home" the wiring for both of those lights on each side intersect i figured it was most likely a difference in load causing this issue so i replaced the corner markers with LED's (194 amber) and that fixed the cluster issue. Issue #2 this is unresolved during the day if you turn the blinker on the parking lamp flashes amber then shuts off - this is normal and correct during the night with parking/headlights on the parking lamp is illuminated white. Per the description from the seller on these specific lamps when you turn the blinker on the white is supposed to turn off and the amber should flash then when you turn off the blinker after 1-2 seconds the white should turn back on. I believe this makes them type 2 but in this situation it doesn't really matter. what is actually happening is headlights on = white parking lights on, blinker on = white parking lights stay on the entire time and the amber dimmly flashes as well. It's so dim that you cannot see it unless you are right up on it. The corner marker LED's operate fine and alternate with the parking lamp blinker. The switchback white is the traditional blueish white LED color IMO it clashes with the natural white 4300k HID headlights i have already since they almost look purple so i'm not a fan of these so far. i'm looking for ideas as to what may be causing this situation or if anyone has had this problem before either way. My mind is kind of leaning towards needing to change the taillights to LED as well. I have never had to do an all or nothing LED install before but this is the first time i have had a vehicle that had a mechanical relay vs being controlled by the BCM or similar hardware. In the mean time I ordered and all amber set of 3157 LED bulbs just to be safe also so i can decide which way i like better. It's not my daily i'm just messing around with all of it so i have a good understanding. I ran out of time tonight to troubleshoot much more in depth. I'm sure if i put the incandescent bulbs back in it will be fine but that's besides the point in my mind. so my idea as of now is install LED taillights and see if that fixes it. If this is the case this brings up another issue in my mind and that's towing. If this fixes it does that mean the second I hook up a trailer with traditional bulbs i'll be right back in the same spot? if that's not the solution then i will just assume LED's i bought off ebay are probably just junk. that's where i'm at as of right now and i'm looking for some opinions. Thank you |
What year is the vehicle?
The wiring of these can be pretty strange in that the stock bulbs have to flow current in both directions to get the corner marker to blink off when the turn signal in the parking light blinks on. This causes issues when switching to leds in the parking lights and turns as the leds do not allow current to reverse direction like a filament does. When I did something like this years ago now and I had similar issues, but I don't recall what I did to fix the issues I had. You have another layer of problems added by going with switchbacks, which have an entirely higher level of electronics that these older blazers were never meant to deal with. Trying to run current the wrong way through something like your parking lamps can cause all kinds of weirdness. Rear lights being led or incandescent shouldn't matter. You may be able to disconnect the corner markers from the parking lights. If you run it this way, you might be able to get a 'normal' current flow through the parking lamps. Then you could tie the corners into the turns only or into the parking circuit only. Or you can try to figure out how to use a 5 pin relay to flash off with the turn signal. |
I had to use load resistors up front in my 04 when I converter to all LED's, despite using a different flasher relay. It's because of the way the current goes through the bulbs in both directions as Thogert mentioned. Odd wiring if you ask me... but after putting load resistors on the turn signal wires at the park light bulb under the headlights, all was well in my case, even after converting the tail lights fully to LED as well.
1 Attachment(s)
2002 4dr 4wd
When I switched the corners to led everything worked right as far as blinker operation. No hyperflash, no cluster lights, but the switchbacks didn't work properly still. The white light stays on 100% of the time and the amber flashes but can't be seen. Picture is of the front end during the day with no lights on. |
(Post 671655)
What were your symptoms that made you decide to add the load resistors? My understanding is 3157 has 12v+ for parking light, 12v+ for turn signal and 2 grounds on the other side. If it was a bulb there is the same thing across two filiments. A switchback should see the constant 12vdc of the parking and when it see's 12vdc for turn it's supposed to cut the 12vdc to the parking white light and only power the amber. That's what has me thinking the problem is the actual switchback. Plus the "white" light on these is somewhere in the 8-10k temp range has me pretty certain they are just crap quality. Just wondering if anyone has working switchbacks and what brand they are. |
Originally Posted by Thogert
(Post 671632)
You could try running the switchbacks off the battery to confirm correct operation. That is what I'd do, but then again I went to school for electrical systems and have fun doing things like that. :icon_shrug:
(Post 671708)
I'd imagine the switchback should be able to handle either +12V on both the inputs at the same time as well as just the turn signal being at +12V. Seeing as some vehicles do not have DRLs.
Originally Posted by cccfabioccc
(Post 671674)
These switchbacks are what I ended up with after my first set were crap... The first different set would keep flickering off when the running lights were on... These ones worked great though, and are BRIGHT. Looked great through clear lenses. http://i.ebayimg.com/images/g/Bf4AAO...D2m/s-l500.jpg Of course my cheap clean lens lights didn't last long before the lens separated, so stockers went back on for now with regular bulbs :P but that'll be changed back soon. |
| All times are GMT -5. The time now is 06:30 AM. |
