Left rear turn signal and brake light not working
I have a 1999 S10 Blazer. The drivers side rear turn signal and brake light is not working. I have checked the bulbs and that is not the problem. The parking lights are working ok.
Any suggestions??
Thanks,
Jim
Any suggestions??
Thanks,
Jim
I would remove the bulbs and check the contacts where the bulbs press in. If there is any corrosion here, it can cause the bright circuit in the bulbs to not work correctly.
ORIGINAL: cliro
have you tried changing the bulb or just looked at it, i've had bulbs that were bad but looked good.
jasondis
Apr 5, 2014 04:54 PM
calgsblaza
Jun 3, 2008 09:46 PM
scottvwcars
Dec 29, 2006 08:46 PM
