Left rear turn signal and brake light not working
Old Nov 15, 2007 | 10:22 AM
Jimonawing's Avatar
Jimonawing is an unknown quantity at this point
Default Left rear turn signal and brake light not working
I have a 1999 S10 Blazer. The drivers side rear turn signal and brake light is not working. I have checked the bulbs and that is not the problem. The parking lights are working ok.
Any suggestions??
Thanks,
Jim
Old Nov 15, 2007 | 10:25 AM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: Left rear turn signal and brake light not working
have you tried changing the bulb or just looked at it, i've had bulbs that were bad but looked good.
Old Nov 15, 2007 | 10:28 AM
I would remove the bulbs and check the contacts where the bulbs press in. If there is any corrosion here, it can cause the bright circuit in the bulbs to not work correctly.
Old Nov 16, 2007 | 12:16 AM
Chevy Lover's Avatar
ORIGINAL: cliro
Exactly. I have been fooled by looking at bulbs before. Either check it with an ohmeter or replace or replace the bulb. That's where I'd start.
Old Nov 16, 2007 | 02:38 AM
Jimonawing's Avatar
yes... the bulbs have been replaced. But as luck would have it, they have started working again last night. It seems to be hit or miss.
Jim
CaptH0wdy
Jul 28, 2015 12:30 PM
jasondis
Apr 5, 2014 04:54 PM
volcer
May 31, 2012 10:44 PM
calgsblaza
Jun 3, 2008 09:46 PM
scottvwcars
Dec 29, 2006 08:46 PM
