No left rear signal or brake light
Old Jun 3, 2008 | 12:15 AM
calgsblaza's Avatar
calgsblaza is an unknown quantity at this point
Default No left rear signal or brake light
So I just got my trailer hitch installed and I take the little skidoo trailer for a test drive and I realize that I have a burnt out rear signal light and no brake light. The tailight works though. So I changed the bulbs and it's still not working. So I figure they screwed something up in the wiring for the trailer lights. I check it and can't find anything wrong with their splices. I used a circuit tester and found that there is no power coming through the trailer hookups or to the signal light. So it's got to be a fuse or something that I could not see. Is there a fuse that I missed that controls only the left rear signal and brake? I did not check the fuse box under the hood only the one in the cab and that is for the entire flasher system. I may just end up taking it into the outfitter that installed my hitch if I can't get it. Unfortunately that is a real pain because of work and all that.
thanks in advance,
Nate
Old Jun 3, 2008 | 08:26 AM
Default RE: No left rear signal or brake light
Does your left rear tail light work on your truck? The turn/brake light uses the same wire from the multifunction switch in the truck. If your tail light works on the back of the truck, then it is a problem with the wiring for the left turn/brake light for your trailer plug. Most likely it is connected to the wrong wire.
Old Jun 3, 2008 | 09:46 PM
calgsblaza's Avatar
I found the problem, under the hood there is a fuse for each turn light, one of them must have blew when I plugged in the old trailer.
volcer
May 31, 2012 10:44 PM
Chris99
Jul 19, 2011 08:19 PM
buddanicholson101
Aug 6, 2010 08:49 PM
kiwi
Nov 6, 2009 10:45 PM
Jimonawing
Nov 16, 2007 02:38 AM
