Lifter Valve???
Old Jun 28, 2008 | 11:34 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default Lifter Valve???
Hello Everyone My 2004 Blazer has a couple issues i would like toask about. First off at idle it has a clicking sound my dads Suburban also has it but it seems Like alot of vortecs have it when i rev my engine the Ticking gets a bit faster with the idle. Also when im accelerating the engine has a rattle sound like a lifter or a valve. Would u suggest an oil change seafoam??? I know vortecs have Carbon problems.
One last issue from park to drive its fine but when i shift the truck into reverse it has a harsh clunk which shakes the whole truck and can be heard how do i fix that.
Thanks gueys.
Old Jun 28, 2008 | 11:45 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Lifter Valve???
On the first issue it is most likely the gm piston slap you can read about it and listen to it here http://www.pistonslap.com/, but if it didn't make the noise in the past and now it is then its probably not it. As for the second issue I take it you are shifiting into reverse on level ground when stopped. Is there any rpm jump or anything else that accompanies this clunk noise.
Old Jun 29, 2008 | 10:28 AM
jman_08's Avatar
There is No RPM jump it does sound like the Piston slap issue so im going to run seafoam today i will keep everyone updated.
marksoftball
Nov 29, 2014 09:27 PM
Chevy33
Mar 25, 2012 11:52 AM
89Recon
Oct 22, 2011 05:50 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
bigdaddykane93
Dec 16, 2010 04:28 PM
