Liftgate strut "sucks", wants to pull liftgate down.
Old Jan 15, 2011 | 03:58 AM
Inferno's Avatar
Inferno is an unknown quantity at this point
Default Liftgate strut "sucks", wants to pull liftgate down.
Okay, here's the deal; the left side liftgate strut doesn't make that nice "hiss" it used to when opening; in other words, air isn't coming out, and as a result, the liftgate needs to be propped open (the right side alone isn't strong enough to counter this). My baby's a 2000 4x4 4dr, and the only thing different today was that I wiped some excess grease from the piston shaft of the strut; I think something is clogging it and preventing air from coming out, which explains why it isn't hissing and wants to pull the thing down. Anybody have the same problem? Do you know where the air is supposed to vent from so I can check if it's clogged? Much thanks in advance!
Old Jan 15, 2011 | 08:15 AM
Longer02's Avatar
Longer02 is an unknown quantity at this point
I would replace the strut. They go bad after years of use.
Old Jan 15, 2011 | 09:02 AM
rriddle3's Avatar
Exactly. They are a replaceable maintenance item.
Old Jan 15, 2011 | 01:24 PM
LRV31's Avatar
LRV31 is on a distinguished road
Replace the pair. The Strong Arm brand has been around for years & Rock Auto has them for around $15.00 each. Part # 4287.
Old Jan 15, 2011 | 03:16 PM
Camaro98's Avatar
Camaro98 is on a distinguished road
+ 1. They are gas struts and are supposed to be sealed. Just like a gas strut or shock on a suspension, when you see greasy residue or oil on the shiny piston shaft of the unit, it means that the cylinder has failed and needs to be replaced.
I also agree on the Strong Arm brand, and that the struts should be replaced as a pair.
Old Jan 15, 2011 | 06:24 PM
Inferno's Avatar
Okay, thanks all for the tip on the Strong Arm brand! I'll look into that (not much around Hawaii, you guys on the Mainland have all the goodies and at cheaper prices!). It's great to have forums like these!
Old Jan 16, 2011 | 09:00 AM
old skool luvr's Avatar
and David, that hiss wasn't air coming out, it was the internal valving letting the fluid pass from chamber to chamber.
and you're right about those guys on the main land, we have the same issue when trying ot order things up from the States.
Old Jan 16, 2011 | 10:25 AM
s14sh3r's Avatar
You guys have O'Reilly there, but some of the stores are called Checker. You can go to oreillyauto.com and find your nearest store. They carry the struts.
Old Jan 17, 2011 | 12:09 AM
Inferno's Avatar
Thanks all, found the last pair of Strong Arm struts at my local O'Reilly; for anyone else who happens upon this thread, prop your gate up and remove the two struts. Attach the new ones at the top first, then hyper extend the gate to get the bottoms into place (so, left top -> right top, then left bottom -> right bottom). If you attach one at a time, you won't be able to push the gate up high enough to get the other one seated, and there is no way that you're going to be able to compress the thing by hand! Not sure if that's what the instructions said-- like most guys, I just threw away the packaging and popped them on. Typical guy thing.
Old Jan 21, 2011 | 11:56 AM
dg98adams's Avatar
dg98adams is on a distinguished road
The rear prop rods in my 99 4 door Blazer are also on the way out.
I found the Strong Arm gas rods at my Local Advance, but there is already 1 review where they did not last a week.
I check GMpartsdirect for factory gas props, and they are like $35 shipped.
I'll probably go that route, since I have went after market before on a Caravan props and they never lasted more than a year until I bought them from a dealer.
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
wooops
Jan 31, 2011 01:02 AM
TheNewKid
Sep 19, 2010 09:54 AM
